thought swapping the FCA out corrected a long crank time. If truck sits overnight it’ll fire up immediately. When it’s warm and turn it over is when the long crank occurs. Truck is not ‘making’ oil. Thanks for any ideas
Crunch is on it You have injector(s) that are bad Heat causing expansion and you can't get enough rail pressure to fire.
