GFreshour,
I think it is along the lines of turbo wastegate opening up and not closing(letting exhaust by-pass turbo) or blockage in fuel system.
Turbo wastegate could be sticking open when you hit max boost(18-20 lbs. ) I don't think it could be the boost (pressure) line coming out of intake manifold and going to wastegate solenoid.
But you could check both line solenoid and rod out easily enough.
I think gate could stick open off/on if solenoid was going bad.
I would have to research though.
Being a intermittent problem, if componenets of fuel system invovled I would think blockage. The filter on bottom of fuel tank model has plugged up on some members trucks. Also the prefilter can get plugged up. Mite be dirt in injector pump.
I quess the question should be when is power loss most noticealbe? RPMs? Speeds?
If wastegate was sticking open low and midrange RPMs would be affected with loss of power.
