Hello all,
I have changed several parts discussed on this forum regarding fuel issues, but am still having a problem. I have almost no power even at 3/4 throttle, and the rail pressure does not move much, and then will behave normally after a short while; this happens most noticeably while using the AC, or just after. I have changed the fuel filter, dropped and cleaned the tank and fuel sender, placed filters on the tank breathers, and replaced the APPS, all within the last 4 weeks. I have also installed dual filter-mounted fuel pumps using a bracket from one of the members; both pumps are new and run simultaneously.
Needless to say, I would like to get to the bottom of this issue. I am beginning to think there may be an electrical problem (short) related to the AC, but I don't get any codes. I would greatly appreciate any input; I have to eliminate this problem. If anyone can help, or knows of a good shop a reasonable distance from Pasadena, Ca. I would be grateful.
Best regards,
J. S.
Best regards,
J. S.
