2nd Gen Non-Engine/Transmission intermittent wipers
Engine/Transmission (1998.5 - 2002) lift pump
Engine/Transmission (1998.5 - 2002) Low boost turbo code
Been having a problem with my wipers. They work fine on low and high. Sometimes the delay function will work for a few passes up to a minute, then there is a click under the dash and they run on low w/ no delay.
Also, the wipers rarely return to "home" position when turned off (motor problem?).
How many times are the wipers supposed to make a pass before shutting off after using the washer? Mine seem to run to many times and wind up leaving streaks.
