Details here: TDR Privileges
does anyone have a problem with interior lights if I open my door the lights come on but go out in 3 seconds my back door it doesn`t even come on . I have repaired the spk. wire I do not see any more broken wires. It use to stay on for 10 min.
See the link contained in the post below. This will cure the three second issue but probably won't help with the rear door. The rear door issue sounds like a wire or the switch that is contained in the door latch itself.
I had the same problem with my 06 i Found the wires were broken. suggestion : add about 3" to them when you heat shrink & solder them together. first time just But spliced together didnt last long. It was a factory screw up. many had the same problem.
