I've done a search on the 3rd Gen forum and have gotten some info on the new lift (pusher) pump.
I have a 3rd Gen on order and will be adding gauges when it arrives. I will definitely be putting a boost/egt gauge in, but I wonder if I need a FP gauge?
From what I'm reading, if you keep your engine pretty much stock, there shouldn't be a problem with low fuel pressure (like my old 2001 had). Even if the pressure should drop to zero, or you pull a vacuum, the engine may stumble, but recover when the fuel returns.
If all this is correct, is a FP gauge really that necessary? If so... why??
