The other thing I was thinking was this:
Those injector holes are REALLY small. Under compression pressure, it would take a LONG time to move enough air to pressurize the tank, especially assuming only one injector is leaking or bad.
But MY tank will pressurize in as little as 2-3 minutes. After running just briefly, I can hear the hissing of the vent tube trying to bleed off pressure as the engine runs. It's just hard to think that an injector could possibly leak that badly, let alone leak that badly and still have the engine run smoothly.
So where else could the air pressure be coming from? I am pretty sure I didn't accidentally plumb my boost gauge line into the fuel return
Ditto for my tires
So what's a guy to do? I installed some Mach 1's in another fella's truck today and they are awesome. The Mach 1s feel every bit as strong as my DD2s. Best of all, almost NO off-boost smoke, even at 6000 feet. The install went smoothly, and there are NO starting issues. I am a little jealous.
My starting issues have been going on for over 2 months now, and it's getting very frustrating. I can't figure out what caused this!! I mean, it went from starting PERFECTLY on the first try to NEVER starting on the first try (at least after it has sat). And it did this in the middle of a tank of fuel, so it wasn't a fuel issue. I changed the filter and it seemed to go away until my wife did a gasser start to my truck (no intake heating) when it was ice cold in the morning. The truck shook violently and spat HUGE clouds of white smoke. Only after shutting it down and restarting did it run properly.
It hasn't started properly since then. Ever since, I have to do the dance where I bump the starter, let the LP run, and only THEN will it start (given a little cranking).
I am worried that all this extra starter cranking is hard on my engine and especially the starter.
Justin
Justin
