Hi gang,
Well it looks like my father is going to have to upgrade his truck. Right now he has a chevy 1500 v-6, so since he went out and bought a 4700+ lb tractor and a 3400+ lb gooseneck trailer he's decided that his truck might not be big enough to safely pull with.
Yes, he did install a gooseneck hitch in the poor 1500 *AND* pull the trailer with a tractor on it. I rode with him when he did this...
Anyhow, he found an Isuzu NPR that is priced in the range of where he wants to spend. It looks like it's in pretty good shape, there have been no obvious repairs done to it and the owner claims that he hasn't had a single problem with the truck in the last 50k (that's all that he has owned it). It has 160k on it. All the owner says has been done to the truck is routine maintenance. Oil and filter changes, etc.
This truck will be used to replace the pickup for daily use as a work truck and will occasionally pull about 10k lbs. Has anyone used one of these like this and did the truck work out well?
It looks to be a well put-together truck that has great engine access (the cab tilts forward out of the way), but I really don't know anything about it other than what I saw when we looked at it.
My dad is not one to get in a hurry (look at the last truck he had), but I am a little concerned that the 4-cyl diesel in the NPR may not pull the trailer at a safe speed down the freeway. I think the truck would need to be able to go at least 60-65mph with the trailer, does this sound reasonable?
Thanks for the help!
Mike
Mike
