Darkbloodmon
NC had its coldest morning temp yet earlier last week if iirc for the piedmont region at 27* aprox. Given the engine work I've done this year I decided to take some observations given the temperature to feel out a baseline of what to expect heading into "cold" weather for the south eastern states.
Batteries are from 2017 Mopar branded lead acid group 65s . Always topped off with dirt free tops/clean terminals, uncoated.
New battery cables/cross cable this year from Geno's supplier
New TYC alternator stock output.
Cold start: Block heater not plugged in over night, Grid heater intact and functioning, Power service in tank and fresh fuel filters on a non heated Titanium Fass 95 prior to a new S&S 6.7 CP3 install in April. Georgia fuel from Duluth QT:00731 11/17/21; 1st and last fuel stop before my return back to NC from Fort Worth Texas.
First crank, nominal turn over within 4 sec spec. No white smoke until after a few moments of idling. White smoke persisted until EGT temp read around 250*+. Battery voltage slowly came up with grid heater draw.
Truck is idling fine without hesitation. I notice as im observing the exhaust pipe (outside the truck) for smoke that the engine speed starts climbing without throttle input and settles at 1100 rpms apprx. I observe for a few moments to see if will continue to climb before popping the hood and giving throttle input at the APP housing throttle linkage lever. I hit around 2500 (by ear) a few times and let it settle. Rpms return back down to 750 and it idles without issue. A few moments go by before engine speed climbs again to settle at 1100rpm. Battery voltage was nominal just past 14v during the times the engine idle up to 1100 without throttle input.
Is this a high idle feature built into the ambient air temp sensor, and grid heater system? Or is it just the grid heater pulling amps and the ECU responding by spinning the alternator faster?
