my single largest complaint is less than par gas mileage. i dont expect 25mpg but better than current.
my truck is a '94 standard cab long bed 4x4 AT 354 gears and 305/70/16 mastercraps and 230,000miles. no lift, no real mods. i do have a straight pipe 3" exhaust and a "holy" air box. very very close to stock. i have a 3 gauge ultralite setup but currently only have my boost gauge installed since i havent got to a drill yet. i have seen boost as high as 28psi, which does not correspond with factory specs. boost at cruise speed of 55mph is ~5psi. i assumed it should be lower?
the speedo has been calibrated to the tires and verified against radar. at 55mph my factory (inaccurate) tach reads 1625. now i know it isnt that precise i just mean directly between 1500 and 1750.
with all of that said, i ve been getting approx 16mpg on the road @55mph hand calculated over a period of several months. always right about the same. this is unloaded flat ground in southern michigan.
a few days ago i packed up to move down here to houston. packing included about 1,000lbs in the bed and about 5,000 behind me. i have no idea of the trucks weight but that shouldnt matter.
i was dragging my mustang on my dovetail 18ft car hauler for the very first time (never pulled anything before)
i had read that the engine should turn atleast 1750 to keep the pump psi up but less than 2100 to keep mpg in check.
that left me somewhere between 60-65mph. i was able to use my cruise control throughout indiana illinois and missouri. heading into arkansas i started to notice the truck couldnt hang in OD. at any slight grade if i remained in cruise with OD on, rpms would jump to 2250 from the normal 1750. quite a jump. i also noticed with od off i was only running slightly more at 2500.
with all of this taken in account, i still got 15mpg even through the ozarks with the trailer. so 6000lbs extra weight, 5-10mph more, and grades and i only lose 1mpg
im thinking i may be blowing through the converter even on unloaded trips? does this sound right or sound like a whole other problem?
