I read in diesel performance mag that if you put the emergency brake on and stand on the driving brake and mash it to the floor that the tac should hand about 1500rpms if not the is a good chance the trans is going. I tried this and mine does not hang at 1500 it shoots right on up to about 2500rpms. The truck had 11,000 miles and the juice has never been turned past setting 1. I do not tow very often and when I have its been around 3500lbs. Also if I mash it on a take off I cant even brake the tires loose. I bought the truck used so I dont know how much power I should be feeling as it is new. Should it brake the tires loose?
Thanks for any input.
