Engine/Transmission (1998.5 - 2002) is there a way to check for defueling?
Engine/Transmission (1998.5 - 2002) ? about twin combo
is it possible to check for defueling while driving with a scan tool of some sorts? what does the it, ECM or PCM ??
The ECM controls defueling. You can monitor the diffrent parameters that can cause defueling but I don't think there is anything that tells you it is actually defueling.
You can watch the fuel pulse width signal get shorter when it starts to defuel. I've used a Fluke low-draw amp clamp and the Fluke 98 automotive scope to watch the signal. Pretty cool stuff! :D Works on PSDs too.
still searching for my problem
big saint, i'm still fighting the same problem with low boost and lack of power. will have more info later. off to the performance shop right now.
later
