On my '97 12v about 160k on it, I have occasional charging, most of the time it isn't, or it was not charging above 12. 1v. I lost the alternator after I changed the fuel plate, at the same time I cleaned all the battery terminals. I do not think the two are connected, but??.
I went in and added a external voltage regulator, to bypass the PCM, now I have no charge, the engine will not turn off with the key. Have to pull the power the to regulator (the power is switched) to kill the engine. Cut the dark green wire (PCM), as shown on the wire chart from hayes manual.
Have pulled the brushes from the alternator, they are worn, but have good contact. The outside brush has a deeper grove in the shaft then the inside brush.
