Engine/Transmission (1998.5 - 2002) is this normal
2nd Gen Non-Engine/Transmission Truck value
2nd Gen Non-Engine/Transmission steering fix questions
I already know my parking brake is dead, I normally have been using a block behind the wheel but I noticed when parking on a hill shifter in 1st or 2nd gear the truck will slowly lurch forward 3-4 inches and continue this. parking up and down hill. is the weight turning the engine over and moving the truck or is this clutch issue. next week I will be fixing the parking brake $ (since it is adjusted to the max and nothing)
thanks
2002 HO 6-SPD LB 4X4 QC HTT 62/14 CON-OFE TST PM3+SMARTY 100HP/JAMMERS AFE/2 4"SILVERLINE ISPRO PYRO,BOOST,FUEL GAUGES,
TURN-OVER BALL, RIDE RITE AIR BAGS. FASS 95/FLOW PUMP, VULCAN 3/8 FUEL LINE AND FITTINGS, FUEL PRESSURE GAUGE, DSS 03 TRAC-BAR DSS BOX SUPPORT 17'' KMC BLACK HOSS, 305/70/17 PRO-COMP X-AT'S COUPLE OF STUPID STICKERS AND DE-BADGED FOR FUEL MILEAGE. :-laf
Yep, that's normal. There's nothing in the trans that locks the driveline. You're just sitting against the compression, which will eventually and always leak down and cause the truck to roll. Here's an earlier thread about it.
Are you adjusting the parking brake via the starwheel in the drum or trying to adjust it with the cable?
with the starwheel inside the hubs. the parking brakes are toast. taking off with them on to many times but its a great way to build boost. ha.
thanks for the input
