ISB 235 engine and boost
which oil???
Differential Question
I think I have a problem but I'm not sure. First lets start with the truck. The black mule is a California truck with a production date of 12-03. She has the ISB 235 engine or 235/465 power plant. She's a quad cab s/b auto trans with 410 for a driveline.
I installed boost gage, pyro, and trans temp all at the same time. The truck has never seen anything over 22lbs of boost since day one. Even after I install the quad box 30-60-100 she still only gets to 22lbs can anyone with an 04 tell me your boost numbers?
I don't want to look for a problem if I don't have one. The truck runs fine and has never been to the dealer for warranty work, I guess I just got lucky. Just in case I just ordered a new isspro boost gage that reads only 30lbs of boost instead on the 60 that’s on her now.
Thanks up front
Bill
Sounds normal, though the boost comes up much sooner and builds much faster. I have the same setup. The '03 SO with CA emmisions is 235hp and 465ft/lbs torque also not 440ft/lbs stock.
bill7975 said:
I think I have a problem but I'm not sure. First lets start with the truck. The black mule is a California truck with a production date of 12-03. She has the ISB 235 engine or 235/440 power plant. She's a quad cab s/b auto trans with 410 for a driveline.
Thanks up front
Bill
I believe that is your wastegate opening - without modifying it will open at 22psi no matter the amount of fuel
bill7975 said:
Thanks I changed it. Have you done anything as far as mods go to your truck??
Bill
I have a Magnaflow muffler in place of the stock muffler, still have the cat, a AFE magnum force air box replacement with a pro guard 7 filter, torque tube, guages, and the adjustable quad box. I have about 47k miles on it, so far it has been great. The only thing that make a noticable difference other than noise was the quad box.
