isb to be 6.7 litre in 07
Ford Owners fed/up with the Powerstroke. Cummins #1
Nice first impression...
SHobbs said:
Rear gear train? Don't tell me that well lets say the engine cover is leaking on what was the front which is now the rear, that would be a booger to fix.
The pdf listings are the specs for the medium-duty ISBe that any truck manufacturer can buy (including Ford for the F650/750). The current 5. 9L ISBe can also have either front or rear gear train; Dodge opts for front for the Ram application.
chrleb1 said:
the rear gear train (makes quieter operation).
Why is the rear gear quieter?
It would be awesome if Dodge opted for the rear gear train; it suggests the possibility of attaching the air compressor that is typically available with rear-gear Cummins engines!
But I doubt Dodge would opt for the rear gear version.
-Ryan
why is rear gear train quieter?
The following is my guess: the flywheel keeps the back of the crankshaft turning at relatively constant angular velocity so torsional oscillation of the crankshaft will make angular velocity at the front more variable; with the timing gearing at the front the velocity oscillations would have more chance of making meshing gear teeth separate and then recontact with a clack.
Lou Klauder
Engine bay is too small as it is; can barelyget to the two back cylinders now. Dodge needs to realize a straight siz is a long engine... hopefully the next body will accomodate the Cummins better (aka longer nose).
