Isb6.7 tsb 18-001-09???
She's dead!
Long trip results
I appreciated the conversation in another thread between TDR members MMullenax and Bob4x4 who are apparently Dodge dealership technicians and knowledgeable about Cummins diesel engines. I began drafting this question on that thread following their discussion then realized I was improperly highjacking someone else's thread and moved over here to start another.
As I understand Chrysler's policy from their discussion, anyone who owns an ISB6. 7 engine still in factory warranty should visit an authorized dealer and have the latest TSB performed whether his truck is exhibiting codes or CELs, or not. I also understand also that the software download should be performed on request at no charge to the owner. Are both statements correct?
The latest issue of TDR magazine (May, June, July 2009) lists TSB 18-009-07 RV B as outstanding for all C&C trucks built before 1/13/09. My truck was built in January '08 and delivered to me on March 3rd, 2008.
My truck has been trouble-free for over 45,000 miles with the exception of a CEL (erroneous reading of fuel rail pressure) which was lighted for a couple thousand miles last September but cleared itself when I hooked up and pulled my heavy fiver 300 miles.
I am reluctant to "mess with a good thing. " In other words, I am hesitant about having a reflash done which may change some operating parameter, fueling map, or feature which I am accustomed to and appreciate.
Is it safe to have this reflash done? Will it actually provide some type of improvement or improve the chances that I will not experience turbo sooting, DPF plugging, or some other dreaded malady? Is it possible that it will cause some unexpected disappointment?
Advice and opinions appreciated.
Following the comments of others on this site, I've seen both positive and negative comments following almost every previous re-flash. Seems almost like a damned if you do, damned if you don't situation. Considering the price we all paid for these excellent trucks (overall assessmemt), I find it disconcerting we have to roll the dice with these updates.
If it's not broke don't fix it... ..... as a rule of thumb..... U can always get it flashed later and they will have more up dates... . Maybe
I had the same dont fix it if it aint broke ,then check engine came on twice at 12,000 then at 21,000 made them put the ECM Flash sticker on the bottom of the hood to denote current ECM Flashes and sign off on it , Software flashes ,turbo and turbo wrap EGR Cleaning etc ,they all seem the same as all 08 users were experiencing . now it is current and up to date on all flashes. And runnning fine for hte moment and thanks to have the warranty . not ready to void anything did pull the muffler and delete it and have duals all the way back from the DPF.
Climbing oil dipstick levels and fuel dilution are a concern and the bypass filter seems pointless as i cant extend 6. 7 drain intervals due to fuel in crankcase from smog stuff
