Hello to all,I'm new to the site. I've installed the Vulcan relocation kit and gauge. I'm having a problem with the erratic readings on the gauge. On the first startup I had 13. 5@idle 11@2000rpm. While driving 12 miles to work the gauge suddenly shot up to 24psi and wouldn't go down. I got another gauge. Figured the first may be bad. Hooked it up 12. 5@idle 11@2000rpm. It worked fine for a full day,then I got home and this gauge was reading 24psi. I've got the isolator mounted in the verticle position. Looks like all or most air is out of the gauge side. I opened the screw to bleed the air out of fuel side. Also a new Carter lift pump. I would appreciate your comments. Thanks
