What drill size are you using on a fuel pressure gauge?
Thanks,
Michael Pliska
Michael,
1/16" to 1/32" for boost depending on plug depth. I have gone bigger with a deep plug.
Fuel and oil usually around 5/64". Again, depends on what I am building and what the use is. Typically, you use a larger hole when at the engine, smaller at the gauge. Obviously, the engine side is better to use.
After my first Isspro gauge rattled many years ago this is the first mod I have done since. My dad and I both have a combine 250K on our boost gauges with no rattle. I run both a 60# along with a 100#. He runs a 60#. Fuel gauges are still fine, although I pulled mine now that I run over 40psi at idle. His 30# gauge was a rattling hand me down from my original set and the snubber stopped the rattling while extending it's life.
The other key to getting boost gauges to last is to get the tapped point away from the valve face and into the horn where pressure is more stable. The valve opening/ closing event along with the charge air changing pressures as a result kill the gauges.
The air example explins what happens to the fuel pressure gauges as they get hammered by 15-30 psi of pulsing fuel pressure. All this due to a sudden drop then spike in the pressure leading into the VP44. Being fuel, location is less important as the compressability is far different than air. But the snubber still is just as effective.
How do you know how big to make the hole? I know how fast the gauge drops off with the truck off. I compare that to the snubber time, It will be slightly slower to drop. This is the resistance to shock.
Simple, effective and cheap!
Oh, if you are loosing senders, this is the easist way to save them! I have an Edge sender that is notorious for failure still kicking after 40K with rock steady pressures.
Dave
