Isspro gauge install questions?
H2 wheels
Oops - 75-140 in chunk!
Isspro gauge install questions? (edit)
Ok, called Isspro and you can add length to the sending unit wires on the full sweep gauges, so I got that part figured out. Now, how do you get to the cigarette lighter wires? I can see them from under the dash but I am affraid to pull on the plastic. I spliced into the orange/white wire from the dimmer for the lighting without any problems. What other power source could I use? or should I just go on a fishing expedition with my 12v tester?
thanks John
just pull the dash bezel off and access the wires to the cigg lighter from there... it's only 1 screw at the trash bag hook thing and then just pull... do it once and run a wire down under the kick panel and you won't need to do that again. .
