It has started...
Upgrade steering linkage part#
Electric sunroof quit working
What level did you have it set on?
I'm on the tow setting... #2, stock parameters. It slipped the clutch (see pictures), but I feel the clutch was bad from the beginning. Everything seems fine now... even impressed the boss who drives Audis... :D
Are you going to Lloyd's Open House?
Alan
Bochuck, my Bullydog smokes very little. I see you are in St Louis too, feel free to contact me if you want to see/drive it.
Thanks Jeepr! I've been considering the Smarty based on a lot of threads here. I'd like to talk to you about your Kore suspension as well. My truck seems to be sagging a little in the back now probably due to use and wear. I tow a boat and noticed that I now have to lift the hitch just a little to put the block under the trailer jack. A year ago I didn't have to do that. Ultimately I'm looking for bringing the back end up to factory specs or maybe an inch or two higher and also bringing the front up an inch or two, all w/o affecting the good daily ride I have.
Just as a follow up... haven't did much traveling, so I have no real mileages to report (its too much fun dipping into the throttle around here)... this weekend, I head for Jacksonville.
One thing I wanted to point out is I think I found why my truck smoked so bad, two-stroke oil. I had been using two-stroke oil at that point, and stopped several tanks ago... now this isn't saying I can't still blacken a highway if I gt into it at low boost, but it is definitely better than it was. So take that FWIW.
