It is waking up :-)
Fly wheel getting turned???
Larger injectors and emissions
This weekend, with the help of JFitzgerald, we woke up my 1992 W-250. We moved the pump 1/8" towards the engine and put a 16 cm hotend housing on the turbo. I am really impressed as it lowerd my EGT by 100*F (to 650*F) at 72 mph and increased the boost 3 lb at the same speed. There is no obvious lag on the turbo and I now have a top boost of 15 to 16 lbs with stock fuel settings. My wife thinks the best part is that the truck is much quieter in the cab. Going through town the truck would shift into OD at 35 mph and just vibrate the cab. You couldn't hear anything or hardly see straight for that matter. Now it is very nice and quiet inside, even with the 3. 5" straight pipe. The truck sounds really mean on the outside though. There is absolutely no smoke or haze from the truck either. I still got 20 mpg after numerous full throttle starts. I also tured the high speed screw CC 1. 5 turns last week. That is a nice modification too.
I am just posting my experiences for others that are on the edge of retiming or changing turbo housings. It is a very inexpensive upgrade and well worth your time.
Glad the changes put a :D on your face. Isn't it nice how these trucks seem to get better with age (and a little tweaking)? Now if I could get the mileage you get... Thanks for your help setting my valves.
cool
Case500D
I just put lucas injectors in mine 2 weeks ago and what a change it made in miy truck. I went from 20 lbs of boost to about 30 lbs of boost. I still have the 21 housing on mine that is the next mod. rite now I am putting a south bend clutch it the truck and it should be done with the BOMBING hahahaaha I dont think it is never done??????? Justin
:D :D Jeremy, think POD's :D :D
You can haul hay and kill skeeters at the same time. . ;)
It sounds to me like steady forward progress my friend. Glad the 'ole gal is coming around for ya.
Stay in touch. .
All the best, Bob and family.
Just like shuckin' corn
Justin and Bob,
If I were to go to the POD injects I am afraid my stock automatic would sound like an ear of sweet corn being shucked out. :eek: Right now I would be happy with a set of 180 hp injectors. Eventually I will get a set of the POD's (after a transmission upgrade). The wife would skin me for having to have the transmission rebuilt. :{
Jeremy
