2nd Gen Non-Engine/Transmission It sure is quiet around here...
Engine/Transmission (1998.5 - 2002) Geno's Map Adapter
2nd Gen Non-Engine/Transmission Whoa nellie!
Need to:
Change vacum pump to timing cover gasket
weeping antifreeze from small pipe that goes into block for heater core
rear pinion seal
rear tires
f/r fender finally started to rot
r/ door bubbling at bottom
Change oil
Check transmission fluid
Discuss if 250,00 miles without changing power steering fluid is a bad thing
new rear brakes on the 01 last night, pads, rotors and calipers. and my brother adjusted the parking brake to so that works great now. he did notice a seal leaking on the drivers side axle. i think we'll have to a install mag-hytec rear differential cover to help fix that leak. :-laf
