ITS ON!!!!!!
It is on and the only words that come to mind is WOOOOOOW... .
Piers has got another WINNER here!!!!!
It is truly a bolt on like his HX-40 no mods where need for the oil return or the exhaust matched up perfectly. The intake side had to be rotated down about 5 deg, although the elbow could have been turned in the hose.
Now for the good stuff... .
It starts making boost at 1600 RPMs and once it comes on hang-on!!!!
The boost takes off like a rocket(I'm going to suggest to Piers to call it the HX-55 Rocket) I am still in the break in phase right now but once tonite it hit 50 PSI at only 3/4 throttle.
EGTs cruising down the freeway(70MPH) are maybe 25 deg higher than the PDR HX-40 was this morning going to work. The boost cruising a freeway speeds is right at the same level as the PDR HX-40.
The EGTs seem to rise faster then stop and drop as the boost get higher. On the on ramp heading home tonite at only 3/4 throttle I entered the freeway at 3/4 throttle and only 1200 deg and 5 MPH faster than normal. At 3/4 throttle my seat of the pants meter tell me that there is more now than before at full throttle.
On the down side...
My top end smoke is gone
the lazer cut delivery valve should solve this.
The rear tires are going to hate this turbo
Thank goodness for Piers giving us junkies the products that keep us in our evering ending quest for for more and more HP.
THANK YOU PIERS for another great product!!!!!!!
