its one color now
sacramento
Just Pulling A Little Load Of Hay
so today I went down & went over the whole truck thouroughly with a scotchbrite pad & shot the 1st coat of primer on
this is a somewhat sandable primer sealer eurothane
Im verry happy mabey in a week or 2 Ill be doneOo.
http://saabpics.nailed.org:3000/gallery/jak/truckonecolor
http://saabpics.nailed.org:3000/gallery/jak/truckonecolor1
http://saabpics.nailed.org:3000/gallery/jak/truckonecolor3
http://saabpics.nailed.org:3000/gallery/jak/truckonecolor2
Ill have to pull the trans back out I found out the pilot bearing & disk are in bad shape I should have checked them while I was doing the trans but I dident :(
the disk grips fine but rattles terrably & the pilot symptom is you pump the clutch once & the trans is noisy & the driveline wiggles in nutral pump it again & the trans is quiet & the drive line is still
I had my local clutch & brake reliner make me a disk for $50 & I bought a new pilot bearing I can do the clutch in under 2 hours no prob so its not that bad
so 1 or 2 coats more primer than a couple of coats of paint the clutch & load my equipment on & yee hah more room & better fuel milage
once again thanks & take care
JAK
I may have all my equipment loaded on in like 2 weeks or so Ill probably have $350 -$400 in paint & suplys I think white is a good color for a service truck & it will hide my screw ups
I have at least 40 hours into the body of the truck including the cutting & welding / rust killing n the floor
this is mostly because there was way too much paint on there from previous repair to paint over so I had to sand for like 25-30 hours
the paint goes on real quick
the instruments you see are my saab which hits 25 lbs boost which is allot for a gasser Im getting almost 250 HP from the 2 litre engine in that one it is heavily modded most are self tweaks like the volvo ECU & air mass meter used on a bigger displacement engine which are able to measure the airflow I push with the bigger turbo as the stock system became useless pretty quick hitting 98% injector on time at 3500 RPM due to airflow :--) it spinns 6200 rpm so it ran outa fuel up top a no no for a gasser
I dont mean to bragg too much on the saab mostly wanted to clear up the instrumentation stuff
I am a boost junkie but I need to keep the truck fairly stock so it stays relyable Ill turn up the timing a lil & feed it a lil more fuel & thats about it oh yeh & an intercooler
I am verry happy & exited to have the truck almost done:D
take care
JAK
edit
PS please feel free to look at the 10 or 11 pages of stuff there you click on the jaks saab projects at the top right than at #s at the top & bottom of the page
89 D350 C&C fresh getrag 4:10s bone stock
