2nd Gen Non-Engine/Transmission Jacked up ball joint
Engine/Transmission (1994 - 1998) #5 Fuel Plate
2nd Gen Non-Engine/Transmission Plastic "welding" - front grill
How does the hole get 'wallowed out'? I may have a found a replacement upper control arm, but while I had the wheel pulled I noticed the PO had the lower ball joint welded too. :-[
Must have received a new welder and needed something to check out his new found skills. By the appearance they are not to good.
Dave
I hear you on that. When I got mine I practiced on sheet metal then progressed up to heavier. But to weld a bj ....
