jacking rear with bags
Power steps
AUX Fuel systems by ATTA
I would like to jack the rear up to add a little rake to the truck.
I was thinking of using the Air Lift add on system. Would the ride just be a little stiffer ,and would that dreaded slam noise go away. Has anyone done this.
If the dreaded slam is the overload leafs banging on the stops air bags will fix that. If you want to lift the rear of an unloaded truck it will probably ride pretty stiff. If you are comping for weight in the bed you will probably love the air bags.
