Originally posted by RMcCulloch
What, if any, are the principle differences between a J. E. B. for a manual and one for the 48RE?
Originally posted by Carlton Bale
With regards to the E-brake shutting off, you are all correct! Here's the deal:
Model Year 2003: The E-brake turns off at coolant temps above 220 degrees F.
Model Year 2003. 5: The E-brake turns off at coolant temps above 175 degrees F. (It turns back on if coolant temp drops below 170. )
As you know, coolant temp rarely reaches 220 F, so MY03 trucks will rarely turn-off the brake at idle. This was changed for MY03. 5 to make this feature more usable.
There are no brake hardware differences at all. The existing E-brake kit would be the one used for 48RE applications if warranty approval were given.
I will start a thread on the 48RE/E- brake when I have something official to communicate.
Carlton Bale said:With regards to the E-brake shutting off, you are all correct! Here's the deal:
Matt400 said:Hi Carlton,
Sorry to re-hash this old thread but I will be installing a Jacobs Cummins part #4089427 on a 5/29/03 build date manual trans and wondered where the cut off is on your above post and if I need to consider a replacement APPS will also be needed?
