Janetty trans temp. manifold
Torque Converter going?
Brake/ABS idiot light
Does the Janetty Trans Temp Manifold come with instructions? I looked under the truck the other day and saw a couple of trans lines. Which one does the manifold go on? I assume it will work with a 1/8 Autometer trans temp probe. Is this correct? Does it come with all the fittings I'll need or do I need a couple of brass compression fittings?
Thanks guys.
Yup.......
Comes with the compression fittings and reducer to work with the 1/8" probe. I put mine on the forward line. That's the output side and will give you the best readings. If you follow it around the trans it goes up to a tank. There is enough straight line there, below the tank, to cut it in. Mine worked great but when I upgraded my trans I spent the few extra and got the line that has a port built in. I took the opportunity to change the fluid and filter at the same time to save on mess.
Good luck,
Garrett
