Jardine 4" exhaust on first gen
Best Tach?
POD Injectors with Tweaked Pump?
Guys,
Big Don here. Been real busy. For starters, Ol Blue now has @ 198,000 miles and the head gasket let go. While I had her down I had the head checked and figured why not make some mods. I went back with a HX 35 off of my 2000 and the same 14cm exh housing on my 89. I put the cast turn down off of a 2000 also. I then took one of the Jardine 4" exhaust system systems I had in stock and proceded to install it on the first gen. It was a system for a second gen truck. I had to clip two places in the firewall/floor pan seam and bent it back. Then I had to smack a dent in the backside of the down piep to choke it in some to clear. Then I had to bend the down pipe a little more where it is already bent, just a little more maybe 5-10 degrees more. Once under the truck everything went well. I used all the hangers that came with the kit and it went great. So now I have a first gen truck with a complete 4" exh with minimal mods.
Just sharing incase anyone has wondered if it will work.
later
Don Peters
Don's Tractor Repair
1120 Cooper street
Church Hill, TN 37642
423-361-5491
Don its good to here from you, we thought that you had dropped off the edge or something. Glad to here ol'blue is alive and well. Was that a modified HX-35 that you put on(bigger compressor wheel) or regular and if it was a modified than did it help? How is the sound of the jardine? Pretty noisy going down the road or? Hope all is well. Danny
