]JCrank asks......
JCrank asks... ...
(Moved here from the FAQ Forum for better/proper exposure)
"..... I just got my first 93 D350 (119,000 miles) this week and I've got lots of questions. It seems there could be auto trans. problems... When first taking off forward or reverse you have to just about floor board it to get moving at all. Once the truck is moving (unless you use the brakes to stop ) things seem to be pretty good. Sometimes when getting up to speed, it sounds and feels like the transmission is shifting up and down. transmission fluid looks and smells good. (What is correct fluid ? ) Does anybody have any ideas ? Another question is how do you test the crank position sensor that takes it readings from the damper pulley. the sensor looks as if someone may have replaced it and laeft the spacers out. I found one spacer and made a second and set the sensor at . 050" gap. The charging system is not working either. Everything else seems in order. ANy help or suggestions are welcome... . "
Thanks ! Jon
JCrank asks... ...
Thanks ! Jon
