juice/attitude '03
Diesel Dynamics Ball Bearing Turbo
Bad fuel or cool weather problem?
installed juice/attitude last night took about 1 hour for quality installation including taping manifold for egt. Night and day, worth every penny. will check mpg gain or loss deppending on right foot. Will post pictures after learn how. NO CODES YET :)
spjohnson said:
Black 2003 4X4 3500 quad, dually,heated leather,infinity, laramie, LB,electronic transfer, 4spd auto 47RE,3. 73, Arma coat, Stull Stainless full length boards,No engine mods (YET!)EDGEjuice/attitude on the way.
Time to change your sig :D So are some transmission upgrades next :cool:
Okay, SP... you have my attention. I need to know the rest... mpg (solo & towing) egt change, towing power, purchase price & seller? Us "S. O. 47RE" owners gotta stick together.
Will be leaving on a loaded trip be gone for 2 weeks. Live in alaska so lots of hills. Current increse on unloaded mpg is an astounding +2. 5 to 21 on the same driving route. As far as egt had no previous gauge, on extremely steep incline getting on it for 1 mile egt 1100. Will give more input upon return. Will PM upon return with price and seller.
EDGE with Attitude performance
Okay folks here it is, net tow weight of 7983lbs(weight being towed minus truck wieght). Total miles 2320 lots of hills in Alaska and into Canada. Average mpg 16. 1 hand calculated,max egt-1220 at 29lbs boost and 100% load , Max engine temp 198 deg F. Very pleased and no codes thrown. Oo. Oo. :D
What settings did you have to get the above figures?
Wayne
amsoilman
Setting one which is milage on the flats and down hill and 2 which is the tow mode for moderate hills and 3-4 on the long steep hills.
In case you didnt feel it, That was the bomb bug that just bit you...
It's all down hill from here :D
how much of a difference is ther between the juice and the ez power wise? I currently have the EZ set on setting 4 and leave it there all the time. no changing since I installed it last spring. Is it going to be worth dropping the extra bucks on this over what I already have?
The attitude is nice, and the low boost fueling is great too. And then there is the HOT Juice that is available. So I would say yes, It is worth jumping up to...
