Yes, I see you have big tires. If you programmed for tire size change then that function doesn't work.boatman said:Does anyone have any ideas?
boatman said:I don't no for sure but I think that I would still see at least some type of percentage on the screen not N for not being locked because I know that the convertor is locked, and one more thing about the Juice is that I read here that the 600/610 engines run very hot and on my monitor I only see 1250 at wide open on power level 5.
CMullen said:I programmed mine for bigger tires and my slip indicator still works...
CMullen said:OK what i did was use my attitude to adjust for the tire size, my ECM is still stock.
JVolpe said:That will correct the speed display and performance test on the Attitude I think, but won't change the actual speedometer or anything off in the ECM because of the larger tires. At least your warranty will last longer that way.
ECappleman said:Why would his warranty last longer, if a dealer did the reflash for tires?
:-laf :-laf I laughedJVolpe said:At least your warranty will last longer that way.
JVolpe said:I was trying to be sarcastic, but I seem to be slipping at everything lately. .![]()
