Jump Starter Pack for 6.7
Electrical question
4000A should start anything!! :confused:
I'd be fine with the 400A
The lithium jobs indeed have different specs than the lead acid boxes. My Snap on box is rated for right around 400 cranking amps. It was primo in it's day. What I like about mine is parts are still available including replacement battery packs.
For some reason they won't give you specs in cranking amps on the lithiums. Makes it hard to make comparisons from one type to the next.
Should but as JR noted its not always clear what the cranking amps or especially cold cranking amps are and there is always loss in the clamps so figured id rather have too many amps then not enough!
I missed the boat... early this morning the NOCO's were 50% off at Amazon. When I went back at 11 am they were only 35% off. So I'm still NOCO-less. :(
