Just a little more outta my Kore ...
How to make a '04 QuadCab into a Mega?
A Big Thank You to a few great salesmen
Just a little more lift. Just a little.
I'm already planning on going to 35's from my 305/70-17. That should do a little bit more.
How about the overload spring? Can I put that back in for just a tad more? Or will the vehicle be adversely affected?
Is there anything I can do to get about 1 1/2" more total inches more?
That's ALL I want. LOL
I ran 35x12. 50-18's Toyo MT's with the Kore Chase on my '03 with no issues other than a little rubbing on the control arm with stock-offset wheels.
When I switched to H2 wheels, no rubbing at all, anywhere.
Now if it's looks you're after, I can't help you...
Order some Lorenz springs.
On edit:
I don't think you can run longer springs w/o swapping shocks...
You don't really want to put the lower overload back in place. It's basically going to be like adding a lift block.
I'd ask the question first, why do you want more lift?
KORE makes some coil spring isolators in front. They replace the factory ones and will add just a little more lift in front while reducing any energy currently being transmitted from the coil to the frame.
On the rear, you could go with a full leaf pack and you might get a little more lift. Again, I'd ask, why do you want more lift?
If you are just trying to clear 35's, it is easy with what you have.
hearingyourlies,
Coil spring isolators already come on a stock truck. However, the stock ones are cheap and get destroyed pretty easily. KORE has a new design for them that are included on the higher end systems. They can also be added separately. They aren't designed to be a lift block, but they will help squeeze and extra quarter to half inch in height. They will also help isolate vibration that is transmitted through your coils to your frame.
You can see pictures of them posted on our website. They are included in the Unlimited, Race and Prerunner systems. They look like black donuts.
demojoe, good talkign to you today, as soon as we get it installed, we'll send pics. We should have it on late next week.
