Just got off the phone with Craig @ Goerend Trans about my New Trans that I am thinking about getting! It is going to be a heavy duty trans, 1 piece sonnax billet input shaft. Lower stall triple disk convertor ~1800rpm. Either a laminated flex plate or billet, still up in the air about that. Mag-hytec double deep trans pan Might stick with the regular output shaft instead of a billet as the weak link. They also said that the new trucks (05-07) has a throttle cable that is controlled by computers instead of the regular TV cable. So they suggested a shift enhancer box to increase trans pressure by engine power instead of throttle movement.
To those who have performance trannys what are your thoughts on this? What you would recommend?
TIA
TIA
