Steve St.Laurent
Staff Alumni
I use my exhaust brake ALL the time. I have a switch on my shift lever (5sp) and also have the micro switch on the throttle. Any time I'm downshifting I push in the clutch and rev the engine up to the RPM that it will be in the next gear down before letting the clutch back out. I did this before the exhaust brake and still do it. It's a LOT easier on the syncro's in your transmission not to mention other driveline parts if you match engine speed to the gear you are going into (this applies to upshifting as well). Also by revving it up between gears the EB turns off so when I let the clutch out it's not putting any extra stress on the clutch. If I'm using the truck brakes at the same time then I brake with the heel of my right foot and use my toes on the throttle - takes a little getting used to but comes naturally after a bit. I also manually turn off the exhaust brake with the switch when I'm accelerating because I don't like the idea of slamming the barn door on the turbo when it's at 43 psi!
By driving and using the exhaust brake this way I feel that there is little to no increased stress on the drivetrain. As said above there is a LOT less force on the drivetrain when decelerating with the brake on than when accelerating (even with a stock engine).
JMHO
JMHO
