I woulda been done hours ago with installing the skyjacker 2. 5" lift front springs, but...
Along with a few other things to let the axle drop down enough to install the springs, I disconnected the track bar from the passenger side of the axle. After putting in the passenger side spring, the end of the track bar wouldn't line up with the bracket on the axle. It was maybe 1/8" or so too close to the drivers side. If I jacked up that side of the axle, it would get a little closer to where it was supposed to be, but I still couldn't get the bolt in even when the spring was at full compression and started to lift the truck. I went ahead and did the other side and got everything else back together, hoping the longer springs on both sides might fix the front end geometry and line everything up but it's even worse now... 1/2 to 3/4" off
I went to check to see if the coil springs were fixing my problem (315's rubbing on the control arms, and they still make pretty bad contact on the drivers side, but with the wheel cut all the way to the left, they're prolly over an inch from the passenger side control arm. So my front end geometry is waaaay off.
How do I get the track bar hooked back up? has anyone else had this problem? Only 2 things I can think of are:
a) tear it apart, take out the spring, lift the axle high enough that the bolt holes line up, bolt it up, reinstall the spring
b) use a spring compressor to compress the spring so the axle moves higher (in relation to the truck) and the trackbar lines up and I can bolt it up... possibly without even having to jack the truck up
Only problems are, with "A", I'm not totally sure the axle will drop down far enough to get the spring in with the track bar install (plus I don't particularly feel like tearing everything apart again). And with "B", while I'm pretty sure it would work, I think my chances of finding a spring compressor that will work on those beastly springs are slim to none.
Any suggestions? help!
