I installed the 275's first and was impressed with the increased power over stock. Today I installed the Powermax setup and I'm really impressed. Truck is definatly quicker than my 96 duallie. Now for the questions. The EGT that came with the system is confusing. The temp doesn't correspond to anything I'm used to in my 96 with mechanical gauge. It appears I'm not getting accurate numbers to the display and the system defuels because of supposed high egt's. I know that we have heard that 1300-1350 is the max egt but for short-a few seconds- do I have to worry? I'm not towing with this truck. 2nd question-the temp sender for the trans fluid is installed in the 1/8" threaded hole in the trans on the right side front just above the pan. Temp readings after warm up run 175-185 f. My 96 has the sender located in the pan and crusing around town it stays around 150 (never above 175) and after lock up it drops to about 135 evan towing. Is it because of the sender location or what? Truck (99) has 70,000 miles with original lift and injector pumps.
