I mounted my Carter lp on the frame (still there). I have a 1/4" rubber pad, then an angle bracket bolted to the frame (the pad is between the bracket and the frame), then on the angle bracket a rubber pad on top, fender washers on the top rubber pad, then a rubber pad on the other side of the angle bracket and the lp top bolted to that sandwich.
Still was somewhat noisy. I could only hear it at stop lights though. It was a conforting sound however, as you could at least hear it.
I did not get to much of the vibrations into the frame, but the motor noise is noticable.
That was before I put the RASP in about a year ago. Mechanical pump mounted up front, no noise.
Bob Weis
IF you do that, PLAN on the lp electrical connector which sticks out TOWARD the frame. ie the bracket needs to be longer on the part that the lp bolts to than the frame side. I think mine is 3" x 4" and I can just barely plug in the lp with it mounted to the bracket. Dielectric grease the connection, power relay triggered by the OEM lp power, and all that sort of thing.
