K&N Dilemma
Hood ornament
Hood ornament
I have heard that some trucks with stock filters had a black residue on the turbo.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors,16cm2 turbo housing, Pacbrake, Walker muffler,
GearVendor O. D. , CenterForce Dual Friction clutch.
Eastern PA.
Fellers,I just got an e-mail back from K&N filters and Don told me that all of their filters are good down to 1 micron,I am satisfied with this preformance and will be going to K&N soon,Like many have said the seal is the most important thing,a little thick grease and vwoila #ad
Kevin 2001 2500 eth dee
Where does this grease go?
01 2500 Sport, QC, LWB, Auto, 4. 10, 4x4, Camper Pkg, Geno's muffler eliminator pipe, rest is stock for now
PUT 85,000 MILES ON MY 12V TRADED FOR 01 INSTALLED SAME FILTER ON NEW TRUCK 18,000 MILES NO PROBLEM
2001 SLT, QC, 4X4 LWB, BRONZE/SILVER 295 75R16 BFG A. T KOs, 29 CHICKEN LITES, CB, 115 GAL TRANSFER TANK, MOON VISOR, GENOS TRANS TEMP, & COMBO GAUGE, SHEEP SKIN SEAT COVERS, CUP SMOTHIE, 3. 54 POSI, AUTO, CAMPER&TOW, CAP, DAUL EXHUST W/10" GLASSPAC &5" TIPS, KC DAYLIGHTERS, 00 RENAGADE ENCLOSED 16' TRAILER, 99 FLSTF, 99 XL 883, (WIFE)2001POLARIS 600 TOURING, 90 RAMCHARGER,(WIFE) 87 YAMAHA 3 WHEELER,
Originally posted by illflem:
On the edge seal dirty side(down)of the filter. IMO the stock paper filter should have grease also.
Don't you mean on the clean side of the filter? Who cares if the dirt gets past the seal on the dirty side?
Paul A. Schmidt
Eastern PA.
After reading several posts a few months back I went and checked mine (K&N) and I found the turbo blades had some grime. I think it just could be from the oil in the filter. I sealed mine very good when I first installed it.
Paul,now you're getting me confused. It makes no difference which side you grease as far as making the seal. The idea,I think,is to keep the grease on the dirty side.
Upper side is the clean side, this should be the one that no dirt should get through. I would also grease the bottom side, this is the dirty side. This should be done as extra insurance. Just do both, for a good nights sleep.
I have the stock filter ( only 1700 miles on the truck ) and when I pulled the inlet tube off the turbo to remove the silencer ring, the turbo blades had a lot of gunk on them. Like sticky goo, not dirt. What could it be?
2001 3500 QC 4X4 Cummins H. O. & 6 Speed, Powermax 2 and needing more power!!!!
I'm happy to report that the K&N is back in and that great turbo whine is back along with much quicker spool-up. I checked the hoses and the turbo blades and was well satified that I'm stoping the dirt. I can not believe how much more restrictive the stock filter is!! I cleaned and re-oiled the K&N and used lots of white lithium grease to seal the filter in its place.
I have used K&N filters on my '93 for over 100,000 miles. Although mine is a first gen truck and the filter has a much better seal I wouldn't use anything else. I have run oil analysis at every oil change (6000 miles) and have never had an oil sample that was not ok to continue using. All dirt contamination was well in the low end of the safe range. If you want to test the K&N do a before analysis and an after analysis and compare them.
Happy Trails
1993 250 4X2 - Banks Power Pack, BD Power Injectors, K&N Air Filter, 6 gauges and tweaked pump. 27lbs boost unloaded.
Horton fan & NV4500 5 speed.
