K& N OEM REPL PART # FOR 2001
Best place for new 5.9
Shock install help
Can anyone give me a part number for a '01 OEM-K&N replacement air filter? Summit could not come up with one, only went to '99. They also called K&N and they couldn't help with an '01 application. TIA--Ron
2001 QC Dually SLT+ 354 LSD AUTO 4WD Driftwood SS Railcaps Stainless Werks step-rail nerfs Rhino spray-in liner Aux B/U lites Diamond Plate Alum Highways tow box SS Fender lips Jardine 4" Mag-Hytec diff & transmission Alcoa classics Reese 20K hitch 28ft Holiday Rambler 5er w/slide 84 Scrambler 4" lift 33/12. 50's 4. 56 gears soft locker/trac-lok Built 258 w/Mopar fuel injection conversion BUILDING 66-442 Olds, ground up--OH BABY! NRA 25 YEAR MEMBER
'94 and up are all the same, I put the one out of my '96 in my '01.
Larry
Ram Rod
'01 3500 white quad cab sport 4x4 ETH DEE SLT+ 4:10s posi Pac brake tow/camper pkg.
35' holiday rambler 5th wheel
I was gonna say, there's a different factory style part number for the over valved engines, but the only difference is they have a piece of foam on the bottom of them, and the K&N from the properly valved ones should work fine. Oh, glad K&N came up. Awhile back, there was a thread about finding that sealing grease that comes with the filter, and how noone could. I said I called K&N and the techy told me white lithium would work fine. Well, I didn't like the way it went on (too runny), and sure enough, with my increased boost (30lbs) I found small traces of the white grease in my hose between the box and turbo. Anyway, to make an already too long story short, I found the grease, NAPA part#765-1351. It's the same silicone based grease you're supposed to use to lube your caliper pins on your front brakes(bet you can tell what I got to do this last weekend).
95 2500 SLT Laramie 3. 54, automatic,Herculiner bed liner, JVC cd out of factory infinity system, southwest grill gaurd (a favorite amongst the deer population), K&N, AFC adjusted, dual straight exhaust out of "gutless" cat, Geno's dual EGT/boost gauge, TST #6 plate slid all the way forward, AFC housing slid all the way forward, silencer ring removed
"Layin' the 'SMOKEDOWN' on their ROOdy Poo CANDY GASSERS!"
Larry, Dan--Thanks for the good info as I was stumped. I would go with the psycotty air thing, I like the design etc, but am concerned about the noise produced, (wife would have a tizzy). Have any first hand knowledge of the noise level??
I moved the K&N filter from my '99 Dodge 3500 to the 2001 Dodge and it fit just fine with no problems so far.
2001 RAM 4x2 SLT "ETH DEE" 3500 QC Flame Red! Rhino Liner, Airlift Airbags, Lance 1130 Camper.
I can't give you any noise info. I did mine at the same time as an exhaust change and it is LOUD especially when towing. Scott1 could help with the psychotty though.
Larry
Only reason I haven't gone to it is I kinda like the little cheesey plunger that tells when the filter needs cleaning. By the way, don't forget with the K&N, don't let it pull past 15" #ad
