K&N Re-0880 or Psychotty
Leaky oil plug tips?
Help me spend my money! 370's gov spring kit.
I know that this has probably come up before, but I can't find a direct comparison in the threads. Which one are you guy running, but mostly, which one flows more/cooler air? I plan on changing mine REALLY soon.
Thanks
2001. 5 3500 4x4 ETH/DEE 3. 54 LSD, HD Transfer Case -- Quad Cab, Patriot Blue, Camper Springs, Tow Package, Everything But Leather, modified 6-way turn signal conversion (thanks Evan), K&N in stock box, 275's, PS boost module,
Real back-up lights, Muffler and res. got knocked off in an off-roading incident (he he).
What silencer ring? #ad
Forget warranty -- BOMBS AWAY! #ad
[This message has been edited by Gizmo 007 (edited 05-22-2001). ]
The Psychotty uses the RE-0880 INSIDE it. All the Psychotty is, is a plastic cover that fits over the RE-0880 filter and then draws air through the windshield cowling. You can use the filter without the Psychotty, but you will be drawing hot air from the engine compartment. There are heat shields available, but you will never get there air cool enough without a Psychotty.
EMD , you need to revise that , the psycotty is not the only way to get cold outside air , its at the moment the only unit of its kind . the air bulldog hood draws air from outside the engine compartment and uses a special airbox that connects to the upper part of the stock airbox and has a tube that surrounds the intercooler to help cool air even further . the air bulldog doesn't use the RE-0880 .
i have the RE-0880 , no psycotty , its to loud for me , the filter alone in the engine compartment is loud enough , i'm going to fabricate a box for it and plumb it to an outside air source
Sorry about the confusion Mopar Muscle. True, the air bulldog hood is another alternative, but for the Bulldog hood plus painting it to match your truck, you are talking about a major expense. A complete Psychotty is about $150. 00. So they are not really in the same ballpark as far as options go for increasing airflow. How much are the Bulldog hoods going for?
to much , i 'm not really sure , but as you stated its not as cheap as the psycotty . i spent about 20 miles in a psycotty equipped truck beore i had to stop and pull it out of the cowl , it was just to much , and then it sucked itself against the end of the filter and made the engine stumble , it need a hard bracket to keep the end of it open .
I use the K&N re-0880 filter and red prefilter. Bought them from summit raceing for around $70. 00 total. The turbo spools up much faster then with the stock air box.
1999, 3500, 6x6, slt, auto, 3. 55 lsd, Qd cab, ISB cummins, Isspro transmission temp, EGT, Boost gauges on A-piler, before and after fuel pressure gauge, DD stage 1, modified banjo bolts, K&N 0880 with prefilter, triple trailing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner. 20,000 lbs GCW.
I have a RE0880 under the hood and it seems to work fine. It lowered my EGT about 50 degrees. I run it under the hood because I want the warm air to be drawn in for the winter when it is freakin cold here is Alaska. Take a look
Got it from Summit Racing. . can not recall the part #'s
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Guard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DTT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. Fuel Pressure gauge, SS fuel lines and lift pump relocation on deck. See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
I am my own warranty station.
Hey guys I love this place too,say I have psychotti also,the main problem is it is way to small at the end and it is choking off intake,I have pulled it off and now running just the filter what a difference i am now breathing very very well,I going to fab out an aluminum wye/branch to go back into cowling and oem fender hole it will work great,when it's done i'll post some pics also some pics of my stacks. hope yall have a great long weekend,
JDM JOE
keep me in mind, I plan to have my aluminum, Psychotty replacement out soon, it will replace the scotty using the same filter and hole, and cure the problems you spoke of. + it is easily polished, to look awesome under the hood too.
look,
if your truck can suck my aluminum one closed, you'll be a rich man. #ad
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's,PowerMax3 adj. , A pillar Boost/EGT,4" turboback exhaust,custom built aluminum airbox W/K&N-RE0860 through the cowl, 310HP/675ft-lbs and more to come...
[This message has been edited by Todd T (edited 05-26-2001). ]
