Hey all,
I removed the timing case cover to check and tab the KDP. I have some observations/questions.
1. The dowel pin appers to be fine.
2. The pictures online are different from my timing case cover. They must be from a later truck? Mine has some extra metal between the bolt and the pin so the $1 dealer tab won't work without case modifcation?
3. A few inches above the bolt that usually holds the tab, is there supposed to be another bolt? I have a bit of stubble there that looks like it might have had a bolt head at one time. The case shows what looks like the washer indent from the wide bolt head.
4. To "kill" KDP should I modify the case to use the dealer part by removing that thin extra metal around the pin? Or should I use a coathanger or other piece of thick steel to fit the case? Or should I do nothing at all - it hasn't moved in 216Kmi it isn't likely to move anytime soon?
Thanks,
Brian
Thanks,
Brian
