We just had a KDP party and did 5 trucks. CPFF's jig comes with a machined aluminum adaptor that allows you to hook a regulated air source to the road draft tube. Basically we hooked 2 psi of shop air to the road draft tube and when you drill the hole, the shavings blast back at you. Once the hole was drilled, we icreased the pressure slightly while doing the countersinking and tapping steps.
