My HX-35 has served me well for 233k with minor fueling increases(3k GSK, 100 plate, stock injectors). I did add a 14cm wg turbine housing since the stock wg failed. During wot runs and sledpulling, my EGT's will climb and max the 1600deg pyro. Wastegate is set at 35psi but as the rpm and EGT climb, the boost will start to creep past that.
My question is, with the soon to be added DDP3 injectors, what steps can I take to keep this turbo from parting itself out? Also, what is the real enemy here? Is it EGT? Drive Pressure? Boost Pressure?
