yogibear said:Doug, I've had the Kelderman 4 link on my trk. for over 110K now, and really like it! I don't think it adds any weight, if anything it may be a few lbs. lighter. Those springs are pretty heavy. You can adjust what height you want your rear to set, and it automaticly goes to that height no matter what weight you have on the rear. You should go to their factory, you are only about 200 mi. from them, its worth the trip to see their facility, and what all they build up there. I plan on going to the KC dyno on Sept. 26th if you want to see the system.
Larry
SRadke said:Unloaded ride is similar to stock. I say similar becasue it's better in some ways, not as good in others. The airbags in this setup are so big I only run about 25psi to hold the back up empty and with a pin load of 2500-300 that ups to 45psi. Loaded it rides like a dream. No bumps, lots of axle travel, it's great!
If it's a smooth empty ride your looking for you need to install larger surge tanks. He supplies surge tanks with the kit to increase the realtive volume of the air in the bag but if they are increased in size the ride would be smoother. Tradeoff is larger tanks would tend to give you more of a floating feel and sway with a top heavy load.
-Scott
DLoughery said:Scott,
Could you explain a little more what you mean by, not as good in some ways?
I'm either running empty or at max GVW, very seldom in between.
Thanks... . Doug
