Hi
I just installed an Edge Juice and CTS and now the key Fob and dome lights don't work till I turn on the key. The key fob does not work either, it will work when I turn the key to run and press the lock/unlock. Also the CTS is suppose to be powered by the connection from the OBDII but no luck I've checked all fuse and still no luck. . I'm open to suggestion so feel free to comment.
PS, not sure if it matters but the truck was just broken into and the rear window is missing. .
Thanks
Thanks
