O. K. , I did the KDP a few weeks ago, here is what I learned. The good news is when I got everything pulled apart and looked at the pin - used a mirror (recommend anyone about to do this get one beforehand unless your pulling your radiators and coolers). It was in there good, all the other bolts tighter than a drum. Still removed the bolts, put some Loc-tite on them and put them back. Of course I did the KDP with the kit I got from Geno's. For us 1st Gen'rs, keep in mind the instructions you get are really geared towards 2nd Gen trucks. So in my case, I did not have to worry about the engine speed sensor. I am a literal person, so had I not checked my FSM first, I probably would be wondering what happened to mine. Speaking of FSM, if you can get your hands on one, I like the instructions for removing the gear cover in it vice what came with the kit. The kit instructions do not make it clear about the plastic guide that comes with the seal should be left in place and "automatically" pops out to be removed. I told you I am a literal person. Vice using the Permatex that came with the kit, I bought a new Felpro gasket - it comes with a seal also, in case you manage to dork your kit seal like I almost did.
Recommend you pull the upper radiator hose to give you more room - I was doing all my radiator and heater hoses at the same time anyway. With the upper radiator hose out of the way, it makes a big difference. Since I was on a roll, I decided to replace what appeared to be the original water pump. Don't forget, weep hole go down.
Get the Barring Tool from Geno's, it is so much easier than crawling under your truck, removing a transmission cover, jamming a screwdriver in the gears.
Yes, removing the fan is a pain, take your time. One of the many times I was thankful I have small dextrous hands. If you have big hands, you better have some good tools. Harmonic balancer - ditto. If you have a low profile impact wrench, it will come in handy. I did not, and there was not enough room to us my battery powered IR impact wrench. I used the barring tool and a cheater to get the bolts out without much drama.
I did not cut out a piece of cardboard to cover the radiator with. You would definitely want to do this if you have a thin finned aluminum radiator, but I was not too concerned about what would happened if the fan dinged it - I had enough room. Did I mention my small dextrous hands?
One thing I would recommend with cardboard is use a piece to hold all the bolts in the same placement as your cover. You have some long bolts which go in specific places - a short bolt will go in a long hole, so it is easy to get frustrated if you throw all your bolts in a pile.
I took plenty of pictures - thank God for digital photography, otherwise I am sure I would put something back together incorrectly.
Knowing what I do now, would I have done it. Yes, it is like insurance, just one of those things you have to do because you just never know. Even though everything looked good, I still got to spend some quality time with my truck and felt good about being able to take a piece of machinery from a running, to none running, and back to running state.
