Engine/Transmission (1994 - 1998) Killer Dowl pin cracked the front gear case
Engine/Transmission (1998.5 - 2002) Need a 6 speed
2nd Gen Non-Engine/Transmission Dumb Bird in the Dash ?
you mean to tell me that not one of you guys knows the specs on a stock cam?
and no one knows the rocker arm ratio either?
wow
hard to believe...
12 Valve rocker ratios are 1. 7 intake, 1. 67 exhaust
At . 050” lift, intake durations are around 155-175 deg. for various stock cams
Exhaust durations are around 195-200 deg.
Lobe centers are around 106-110 deg.
holy cow, no wonder you can adj half the valves with out spinning the motor over
155?
never heard of such short duration joe
the advertised number could be less than 180°?
i dont even see how it could work. wouldnt the side of the lifter run into the side of the lobe? are they roller lifters? man, that is short...
thanks
